07-26-2021 09:50 PM - edited 01-06-2022 02:54 AM
07-27-2021 06:05 PM - edited 07-27-2021 06:06 PM
How To Activate Online visit Here for more information,
Activate your Public Mobile SIM card
You'll be up and running in just 4 easy steps, Here
Plus, get 2GB of monthly bonus data for free* when you activate on plans $35/mo+
online only for that Promo code for 2GB , 2GBBONUS , that monthly bonus for 2GB no expires but you have to keep your plan and if you changed your plan you will lost the promo 2GB you know,
put it the email for it and the same email when the do a new activate, HERE
Good Luck and your welcome to public mobile
with a Beautiful Service
you will be very happy
07-27-2021 05:55 PM
Before you activate your new SIM card, make sure that your device has been previously unlocked and confirm that it is compatible with our network using our compatibility tool :
To activate your SIM card, go to activate.publicmobile.ca and have your SIM card ready. If you are transferring your existing phone number into Public Mobile, make sure you also have your old SIM card on hand. Here’s some additional guidance for each section of the activation process.
SIM Card
07-26-2021 10:02 PM
@Claudebigras wrote:how do I register my new phone
There's no registering a phone. Compatible phones work after you put your sim in.
07-26-2021 09:58 PM
Hello @Claudebigras ,
If you are an existing customer and you would like to change phones, then remove the SIM from the old phone and insert it into the new phone (ensure it is compatible with Public Mobile).
SIM's normally come in 3-in-1 sizes. So depending on the SIM slot of your old vs. new phone, it may be the same, or you may need to remove or add the outside adapters of the SIM card.
07-26-2021 09:54 PM - edited 07-26-2021 09:55 PM
@Claudebigras are you currently a PM customer? If so, simply move your SIM from the old phone to the new one. Usually it works without much works, but in some cases, you might have to setup the APN manually
If you are not PM customer yet, you will have to get a PM SIM first, once you got it, you can activate here: https://activate.publicmobile.ca/
