New phone
11-30-2024 04:05 PM
If I purchase a used android phone, (I currently have an Samsung A5), do I understand correctly that I simply swap the sim card, and there is no further set up to start using the new phone?
Phones
11-30-2024 04:50 PM
@Danguitaraddict just adding to what has already been shared, don't forget to install the Public Mobile app on your new device
11-30-2024 04:24 PM - edited 11-30-2024 04:25 PM
Hello @Danguitaraddict
Yes and no. Check out this list to see if it will work on Public Mobile. Which phone is it?? Also, be careful of buying a used phone. They may be from another country and if a factory reset is done, it may be locked.
Here's the thing. It may work on the 3G network but may not work on 4G or 5G. And if Public Mobile doesn't add it to the whitelist when 3G is dead in Canada, the phone will be useless.
11-30-2024 04:09 PM
@Danguitaraddict - Yes, that is true, just remove SIM from old device and insert it into New Device and your phone number is moved.
There could still be a trouble though if you have an issue with the APN or calls, texts, or data use. These settings are changeable in the Cellular settings on the new phone. APN link: https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
11-30-2024 04:08 PM
yes, just put the sim in the new phone
if sim is too big, there is a outside you can remove to make it smaller
