07-11-2022 09:43 PM
When I try to use phone it gives a message number not registered. What do I do?
07-11-2022 10:46 PM
You missed the final step. You need to power off your phone by holding down the power button then wait 2 minutes and power on the phone.
07-11-2022 10:13 PM
@Smorty323 wrote:Maybe it took awhile for the phone to get activated. I just tried a call again and it went through. Thank you for trying to help me. Shelley
@Smorty323 So, it works now? I guess you did a reboot as well?
Anyway, enjoy your new service.
07-11-2022 10:12 PM
@Smorty323 is the actual error "SIM NOT registered" or "SIM not provisioned"?
It sounds like an issue with SIM provisioning. It is an easy fix on the PM side but you need to open ticket with them: open the ticket now using one of the method below:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
07-11-2022 10:11 PM
07-11-2022 10:09 PM
Just activated Sim card and got a new number
07-11-2022 10:04 PM
I put a new SIM into new phone and Public Mobile gave me a number.
07-11-2022 09:46 PM
@Smorty323 did you just registered an account?
You said new number. Did you just activate and picked a new number? or you hare existing PM subscribers and just perform a "change number'" request and picked a new number?
Give us more information and we will try to help
