10-12-2021 06:01 PM - edited 01-06-2022 03:31 AM
I just moved my pm sim into a new phone and everything works except sending pictures via mms. I can receive pictures fine. Any idea if there is a setting in Android 11 that would prevent sending mms pictures?
10-12-2021 06:28 PM
@ChuckYeah wrote:@Anonymous resetting the network settings and re-inputting my apn worked. As far as I know, I put in all the same entries, but lo and behold, it's working now.
Thanks.
your welcome
glad it works
enjoy your service...
10-12-2021 06:21 PM
Thanks.
10-12-2021 06:19 PM
Try resetting your network connections.
You might also make sure Android Chat settings are disabled and any MMS settings under your Message app are set appropriately or enabled (if displaying otherwise).
10-12-2021 06:16 PM
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
for iphone go to Settings > Messages > To turn iMessage on or off,
Turn your data on to send a Picture Messaging in world-wide,
if your data is off and your home internet wifi is on is not going through the Picture or a video Messaging,
you have to do this to is going through you will need to turn your data on to send a Picture or a video Messaging in world-wide,
make sure your Data is on.
orcan you try manually selecting network "3G ONLY" or WCDMA only,
for android visit Here link ,
and do Rebooting your phone
10-12-2021 06:10 PM
Yup data is on and apn is set. Only outgoing mms is affected.
10-12-2021 06:09 PM
Try clearing your cache.
Tap on the option that says Clear Storage followed by Clear Cache.
Relaunch your MMS app.
Also try rebooting your phone.
If that does not work try resetting your APN settings.
10-12-2021 06:08 PM
Do you have your 'data' ON?
It will not use your data allowance but data has to be ON (at least on Android, assuming same for apple).
