Request for iphone iOS 18 users: RCS related
on2wheels
Can iphone users who use RCS do me a favor, I'm trying to figure out if the problem is my phone or with PublicMobile service.
When you have RCS enabled and are texting someone who uses Android and also has RCS enabled, you will have the status indicator showing "RCS" in the typing box.  After you tap send and the message goes, does that status indicator briefly change to SMS then back to RCS?
@on2wheels
The RCS works on my iPhone 14 Pro Max. Depending on the model of your iPhone. Enable it on your iPhone. Go to Settings>Apps>Messages>RCS Messaging>enable RCS Messaging. Older iPhones won’t have this setting.
@on2wheels  Mine stays in RCS after I reply with android people
will13am
@on2wheels , I have an android device.  I communicate via RCS with other iPhone users and RCS works fine.  From my understanding, whether the communication is via old SMS or RCS format is determined by google.  If both parties have RCS capability, it becomes the default protocol.  Public Mobile has no role to play here.
Rastin
How old is the android? Is it capable of rcs? Have you tried more then one person with android.
