05-13-2019 10:02 AM - edited 01-05-2022 04:54 AM
I'm wondering if I am able to switch my information to a new sim card?
The new phone I want to use only takes a nano sim card, and my old sim isn't nano. I don't want to cut it myself lol. I ordered a new sim card. Is there any way I can transfer my plan, phone number, etc to the new one without starting over? Thanks
05-13-2019 11:53 AM
Perfect! Thanks everyone!
05-13-2019 11:00 AM - edited 05-13-2019 11:01 AM
@Maria_whatever wrote:I'm wondering if I am able to switch my information to a new sim card?
You don't need transfer your plan, phone number, etc. after receive new Sim card. log in your account and chose replace Sim card option.
05-13-2019 10:37 AM
@surreybozObviously not
Noted with thanks!
05-13-2019 10:33 AM
@geopublic wrote:@surreyboz True but it appears that the OP signed up in 2019.
You didn't bother to read OP's post and replies correctly. They have a six year old Sim card.
05-13-2019 10:31 AM
05-13-2019 10:29 AM
@Maria_whatever Public Mobile sim cards are tri punch. You card can easily convert to nano. Please use this picture as a reference just need to put a little pressure on the card.
FYI: They weren't always tri cut. Tri cut Sim started around 2015/2016 with a suggestion of a Public Mobile Community member @chukdefatey Before that you had to order each Sim size individually
05-13-2019 10:25 AM
05-13-2019 10:23 AM
@Maria_whatever, switching SIM cards is a relatively easy step that you can do in the self serve. Just select the change SIM card option and type in the new SIM card number, insert new SIM card into the phone, reboot. The change takes place immediately.
05-13-2019 10:22 AM - edited 05-13-2019 10:23 AM
Public Mobile has a Pretty Decent self serve site, which let's you do a lot of things yourself. Log in to selfserve.publicmobile.ca when you have your new tri-cut Sim in your hand and simply do a Sim Swap from your old Sim to the new one. It immediately gets swaped onto the new sim
05-13-2019 10:22 AM
Yes. Log-in to your account, then in the "my profile box" choose "change SIM"
05-13-2019 10:22 AM
For sure you can change the number of your new sim in your self-serve account in tab PLAN/ADD ONS CHANGE SIM NUMBER and you will not loose anything.
05-13-2019 10:09 AM
Yes, the old sim is my original one from when I started with public mobile, about 6 years ago. It's been through many phones, so really don't want to attempt the cut myself.
05-13-2019 10:04 AM
Is the "old" SIM really old? Is there a chance it was a tri cut SIM, and maybe it just needs to be punched out?
Just checking
