New SIM number not recognized and phone not working
Seanu6
I bought a new Public SIM card when my old phone was lost.
Public system doesn't recognize the SIM card number as valid.
I have no phone service.
@Seanu6  Are you changing sim card after you login to My Account?  if you are, then you are in the right place.  But try again using desktop or laptop computer
@Seanu6
Double check the 9 digit number after 8912230000xxxxxxxxx.
If it first 10 digit 8912230000 is not the same then you don’t have a PM SIM.
@Seanu6 - where are you getting this invalid issue? You should be in My Account and perform a SIM-SWAP.
See "How To Change Your SIM Card" in this Help Article: https://www.publicmobile.ca/en/on/get-help/articles/sim-swap
Have you listed your phone/account in lost/stolen status in My Account? Or is it suspended or Active?
Get your account Active status then try again.
If issues with your My Account, click here to request a SIM Swap with the Public Mobile Customer Support Agents (CSA): Submit ticket for a SIM SWAP
dust2dust
How many digits in the sim number? This place is 19.
You're using the account to change sim right? Not doing a whole new activation?
pmbc
@Seanu6  Did you buy this direct from PM or 3rd party?  If it's not recognized as a valid SIM you're going to need to get another SIM.  I'd suggest contacting support to have them validate whether the SIM is valid or maybe it was a previously used SIM that's no long active.
You can contact an agent using the chatbot.  Type "agent" and click contact us to go through the wizard.
If for some reason they don't respond to the ticket, you can try to send an email directly to the CS Agent here.
Here is a help article about how to contact the CS Agent.
