New Public Mobile customer. Calls and SMS not coming through -- only data.
emmyrose
I transferred my number over from Rogers about a month ago and haven't been able to receive calls and SMS reliably, only iMessage and Facetime calls. I also put in a reference code from my friend but it hasn't been applied on his end. I don't have access to my old provider's SIM card. Any idea what's going on? Thanks.
7 REPLIES 7
@emmyrose wrote:
Strangely, I can receive calls and SMS from my partner (who is also on Public Mobile), we just tested it. But most friends say they can't reach me, and when I need an SMS/Call verification code, like for signing into my bank or something, it never comes through. But I DO receive calls (not facetime) and texts (not imessage) from my partner.
@emmyrose   the text you got from your partner, is that iMessage?
what exact date you activate?  if it is less than 30 days, login to My Account, go to Profile page and check your current phone number. Is that the number you are porting in from Rogers?
If it is less than 30 days and you see your phone number on My Account's profile, let us know, we can send you PM/Telus porting team number to call and confirm the porting status
emmyrose
dust2dust
What's the status of the Rogers account? Did you do anything to it yourself? If it's closed and you didn't close it then that part is done.
Connect to wifi and go to settings, general, about and see if anything wants to update.
I don't know if the AppleID side of things needs to care about the provider.
In imessage, turn on send as sms and send as mms.
Can you find a setting saying volte?
emmyrose
Thanks for the replies. I should be more clear -- I can make outgoing calls and can sometimes receive calls (not facetime) but it's often very unreliable and most SMS do not come through.
emmyrose
I recall receiving the SMS from Rogers to confirm the port (with my old Rogers sim inside). Would I need to do anything beyond that?
dust2dust
It sounds like you didn't leave the Rogers sim in a phone to confirm the transfer. Can you still log in to your Rogers account or did you cancel it yourself? Is it possibly still active? You might need to buy another Rogers sim and apply it to the account and then put it in a phone. Then call a porting help line to re-trigger the port.
Did you get a $10 credit in your balance?
Yummy
Are you sure porting number from Rogers has been successfully completed?
Were you able to receive calls/SMS since you joined PM?
Both account have to be active in order to successfully port number to PM.
