04-17-2023 10:34 AM
My phone works as it should with texting/calling/data I'm trying to use my phone number as a verification step for different apps but when I get to the page where it says, enter the code we texted you. I'm never getting a code. I've double triple checked I put the right phone number in. I don't know how to fix it.
04-17-2023 10:59 AM
It's not a bank. But I will try again in a week. Thank you for all your help! 🙂
04-17-2023 10:47 AM
@H_bowman94 if you are able to receive incoming calls, then no worry
As you only activated for 48 hours, many 2FA text won't start coming until after 3 days. And many 2FA from banks could come as late as a week.
Reason is that those 2FA text are system generated text and take longer time to find out you ported in your phone number. Also, some banks purposely add the extra delay as well in case of sim fraud
so, you should be getting ALL Your 2FA text after one week
04-17-2023 10:45 AM
@H_bowman94 wrote:I have an actual mobile phone, no landline. I've never been able to recieve a code since having public mobile. But I've only been active 48 hours. I'll try again next week maybe?
Ah, OK.
Sometimes 2FA require longer time for brand new numbers to 'find' a way to these numbers.
04-17-2023 10:39 AM
04-17-2023 10:36 AM - edited 04-17-2023 10:36 AM
Sometimes it takes some time for 2FA to arrive.
Did you port Land line or you have 'real' mobile phone number?
Were you Ever been able to receive this 2FA codes or this is recent occurrence?
