11-21-2018 04:57 PM - edited 01-05-2022 02:33 AM
New to Community
Just went onto my account and noticed that there are new plans being offered. I am currently on $120/90 day Canada wide talk, worlwide text and 3gb data. When I go to create your own plan the same comes up at $105. Did the prices go down? How do I go about changing my plan then? I just auto renewed on Nov 13th. Can I change plan now or do I have to wait til Feb?
11-21-2018 07:13 PM
Thanks for the info!
11-21-2018 06:57 PM
Price comparison if you need it 😉
@Someone_here wrote:New pricing table 🙂
I changed the design a little bit, I think it makes it easier to compare...
Enjoy!
11-21-2018 05:09 PM - edited 11-21-2018 05:11 PM
@Suzielou wrote:New to Community
@SuzielouSometimes prices go up, sometimes prices go down. This is one of those times it went down. Its one of the biggest events of the year (black friday) so this is when the price should go down.
Log into your account, select the plan you want and hit "change at renewal" so you will "lock" in that plan as your own. No point to "change plan now" as it will cost you a lot since you just renewd.
The price went down by $15 which you have already paid. If you change plan now you will lose over $100. If you change plan "at next renewal" you will only save $15 for each 90 days going forward.
Save money, or spend money for the same thing.
11-21-2018 05:01 PM
Probably the cheapest and easiest way is to change plans (to lower cost plan) at the next renewal date. If you change immediately, you usually will forfeit the remaining amount in your plan which you just renewed.
The prices have gone down for certain plans to remain competitive with the rest of the tier 3 mobile companies.
