12-30-2022 06:23 PM
Last month I changed my plan from 3 g and 3 gb for $30 to the 15 gb and 4 g for $40. It was changed to 3g and 3 gb for $35. A week ago I went in and changed it again to the 15 gb and 4g for $40 and today I logged in and it had been changed again.
Today I changed it back to the 3g and 3 gb for $30. If it is changed again I'm not sure what I'm going to do
12-30-2022 06:53 PM
Your better off, reaching out to a Customer Support Agent for help with that, like I suggested before.
Just use the Chat Bot Simon to get a service ticket started first.
12-30-2022 06:46 PM
HI @clemmer88
honest, your situation is a bit complicated
open ticket with CS agent and get them to check:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
12-30-2022 06:45 PM
EVERY time you change plan NOW you will be charged new plan cost with no refunds nor cost adjustment.
To see which plan you currently have use incognito mode or below clues.
Public Mobile has web page cache issue so you might be looking at obsolete status. Click on little spinner refresh icons lower down. Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
12-30-2022 06:45 PM
@clemmer88 @So are you able ? Then refresh page with the yellow spinner .also going from 3G/4G you can take up to 48 hour before you see a speed difference just a heads up there
Refresh page ^^^
12-30-2022 06:43 PM
@clemmer88 do you remember if you select Change Plan now?
and how many times PM charged you? Just once? or more?
12-30-2022 06:43 PM
You should probably reach out to a Customer Support Agent to get help with that problem your having.
Use the Chat Bot Simon to get a service ticket started first.
12-30-2022 06:42 PM
renewal date
it changed my plan just not to what I chose
why would I go from 3 gb 3g $30 to 3 gb 3 g $35
12-30-2022 06:26 PM
Try logging into your account using a different browser in incognito or private mode instead.
Try again and you'll probably see the most recent information in your account.
12-30-2022 06:25 PM
@clemmer88 you shouldn't be changing it back and forth
Did you use Change plan now or Change on renewal date? I hope you didn't use Change plan now or PM will be charging you immediately
Login to My Account again using Incognito mode and see what plan you are in now. Check payment history to confirm PM didn't charge you couple times
12-30-2022 06:25 PM
@clemmer88 @Try again incognito mode there’s cache issues . It should be there for you
