4 weeks ago
I just recently purchased the 50 dollar plan went through everything good and fine put the IMEI everything was good, go to download the app and now it says eSIM not compatible, I’ve tried everything can someone help?
4 weeks ago
If you got the error ""SUBSCRIPTION NOT ACTIVATED" or " Unable to Activate eSIM" at step 6, Reboot your phone, re-login and the app will try to complete the activation
If same, then remove the old carrier sim card, or if it the old carrier sim is esim, disable it from Sim Manager or Settings->Cellular
Then put the PM sim card in the phone, or if eSIM, you should be good
Next, go to Sim Manager or Settings->Cellular and check if PM sim is showing there. Make sure the Public Mobile sim is enabled , or Turn on this line option is toggled on. Also, change the label to Primary
Reboot your phone and Reset network settings and test and confirm if all work or let us know of if any the following does not work: inbound and outbound calls, inbound and outbound text, mobile data.
if the sim not connecting, ask PM support agent to help. You can submit ticket by direct message:
4 weeks ago
Try reboot the phone and re-login the app and see if the app can complete the activation.
But if you still get the same error, you will have to ask PM to help. Simply open ticket with PM using Expert Messaging. Click the Orange Chatbot icon on the lower right to start, or use this link https://widget.telus.tiia.ai/libs/chatbot.html?botId=ZJkWuVb7Hp6EEcTIZKMZbvLwuDV&lang=en&toggle=fal...
PM will reply you via Expert Messaging between 9AM-10PM EST (Mon-Sun)
(for help with Expert Messaging, check here: https://publicmobile.ca/en/get-help/articles/expert-messaging )
