New Canada USA plan
03-01-2024 07:57 PM
Hello. I have the new Canada, USA plan. I live on Vancouver Island and I'm still roaming to USA on regular public mobile network. I turned roaming on and have 180mb data so super fast but just went through 1.5 Gb in 3 mins. I didn't think that would happen so what's going on?
Service
03-04-2024 01:54 AM - edited 03-04-2024 01:55 AM
@MD250 wrote:Can you roam on the Rogers network between Sooke and Port Renfrew like Telus and Koodo can?
Public Mobile customers cannot use Candian roaming networks.
03-04-2024 01:21 AM
I don't know, as I have never tried it.
03-04-2024 12:26 AM
03-02-2024 10:17 AM
I have experienced this Between Sooke and Jordan River.
03-01-2024 08:45 PM
Where are you in Victoria that you are constantly connecting to the US? Are you in James Bay or out in Metchosin? I am in Colwood and experienced this yet
03-01-2024 08:43 PM
I switched my plan today. I've just turned phone on and off and data is way better now. Not roaming even though I have it on but says public not US network. As typing its switched to USA again. I've used .5mb since we started chatting. Thx. I know nothing about phones.
03-01-2024 08:21 PM
No. Roaming doesn't create increase. I'd suggest downloading an app that monitors your data usage to see exactly what is using your data. Just something to help keep an eye on things.
03-01-2024 08:16 PM
self solution removed
03-01-2024 08:12 PM
Thx . I'll keep an eye on it and reply if needed
03-01-2024 08:07 PM
Just using my subscription data page. I keep refreshing it to see how much is being used every few minutes. I did go on line to look at web for a bit and lots of data used so is roaming causing the increase?. No video watched.
03-01-2024 08:00 PM - edited 03-01-2024 08:01 PM
What were you watching? Plus, the data stats aren't accurate. They are updated twice a day. Usually just past midnight. So the stats you're probably reading are for the last 12 hours.
Curious though. How do you know it was 1.5GB in 3 minutes? Are you using an app to monitor it?
