New Canada US plan on promotion
LeonS
The new promotional plan seems to show that you can use your data and minutes in USA.  Is this correct?
7 REPLIES 7
hi @LeonS what phone do you have??
LeonS
It seems that it did work - finding the roaming setup was the problem. Thank you
Moved:
unnecessary repetition: the question was answered nearly 7 hours earlier
99guy
Just got back from LA, no issues at all.
eddieO
@LeonS yes, it works on both sides of the border with no surprise extra costs. Just make sure you have Data Roaming turned on and that you are connecting to either T-Mobile or AT&T. Some are saying that Verizon also works but it didn't work for us but no harm in trying.
Customers can use all plan features of a Canada-US plan while in both countries.
