02-11-2023 09:23 PM
02-12-2023 05:25 AM
Did you buy your phone brand new from a reputable source? Do you get the same message with another provider Sim card in the phone? Check if it's been blacklisted below...
02-11-2023 09:26 PM
@Weeya first , loigin to My Account using Incognito mode. Confirm if the account status is Active or Suspended
If Active, the try to Reseat your sim card (Power off the phone, take out sim card for a minute, then put it back and Power it back up)
If still does not work , test the PM sim card in another phone to see if it works
If you can test it in another area, please do so
If nothing works but accounts shows Active, you might want to confirm with PM Support:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
