6 hours ago - last edited 4 hours ago by computergeek541
Hi community!
I'm wondering if anyone can tell me more about the network selection options, specifically what is 999 40? Is it best to use automatic or select public mobile manually?
Thanks!
6 hours ago
999 40 is probably a private network. Stick with automatic, no need to mess with anything unless you're having big problems.
6 hours ago
Never seen that code before.
I would select PM automatic.
6 hours ago - last edited 6 hours ago
