05-22-2026 10:54 AM
My phone suddenly lost connection to the network and despite rebooting, is not connecting back. How do I restore connection?
05-22-2026 11:34 AM
@MJ20317 wrote:Problem solved, thanks to all who provided inputs
Care to share your experience ? What did you do to get it working ?
05-22-2026 11:21 AM
05-22-2026 11:09 AM
thanks, using esim
05-22-2026 11:02 AM
check the Telus Outage page to confirm if there is any outage in your area
https://www.telus.com/en/bc/outages
Also, login My Account to confirm if your account is active or suspended
if it is active and there is not local outage, Restart phone and Reset network settings
and you can ask ask PM to check and confirm your account on the system. Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.) When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox, between 9AM-10PM EST (Mon-Sun), check here:
05-22-2026 10:59 AM
if you're using a sim card, try removing it ...then re-install...see if thathelps.
Alternative...try your sim in a diff cellphone.
Ignore both suggestions if you use esim.
