2 weeks ago
my current plan includes canada, usa, and mexico. when we arrived in mexico our phone did not connect with a mexican network until I connected to the internet in our room. when we leave our complex we loose connection with the Mexican Network. my question is should I have roaming on all the time?. Any other settings that I should turn on or off?
2 weeks ago
thank you
2 weeks ago - last edited 2 weeks ago
exactly right...leave Roaming on all the time when you're in Mx. You can connect to the better of AT&T, Telcel or Movistar.
added...if you're worried about unexpected roaming fees or overage charges; worry not because there are none of those. You can use your Public Mobile plan in US and Mx just as if you're at home.
