Network but no internet/data?
Yourbakerman
Just got back to Canada from a trip. Was not able to log into the site. Which we got resolved now my phone works with text and location but says there is no internet connection when I use Instagram, tick-tok or my web browsers. I have tried to reboot the phone multiple times ?Screenshot_20240212_104806_TikTok.jpgScreenshot_20240212_104821_Edge.jpg
Yourbakerman
Awesome thx worked like a charm
Yourbakerman
HI @Yourbakerman
should be an APN issue. Fastest way to resolve is to "Reset All Networks".  Try
@Yourbakerman
click Reset all networks on your phone.
Also, check the VPN screen, make sure there is no VPN profile there.  Best to delete them if any showing there
