My account
02-12-2024
11:15 AM
02-12-2024
09:22 PM
computergeek541
02-12-2024 11:29 AM
Did you port your old number over to PM or pick a new number?
If you picked a new number just reboot your phone by powering off then back on.
If you porting over, did you reply to the text with YES with the old SIM in your phone confirming you are porting over to PM?
You have 90 minutes to reply or porting will be cancelled. You will need to contact a CS_Agent by DM at to restart the porting process:
