08-14-2020 01:05 PM - edited 01-05-2022 12:47 PM
I was at Shoppers Drug Mart in Vancouver, BC and had no signal to make a phone call. I live in central area of Vancouver. I had no reception issue in the area with my old carrier. I just recently switched to Public Mobile. In my house, I have only 3-4 lines of the signals shown on the phone. Is there anything I can do to improve the network?
08-22-2020 04:24 PM
I guess no frills extends to your mobile coverage too once you enter their retail locations.
08-22-2020 02:13 PM
Usually when that happens, it could be the building blocking the signal. I've had that problem especially at No frills with other providers too.
08-15-2020 08:39 PM
Thanks for letting me know.
08-15-2020 04:20 AM
I live near broadway and main in vancouver and my reception is excellent. Occasionally i will lose reception in back corners or deep into no frills on broadway and the one on west fourth. And near the back corner of save on foods (dairy section) at cambie and 7th. The stores on the ground floor of a large concrete condo building or hi rise can lose reception once you hit the middle of store/building.
Those two grocers the only places ive noticed any issues on the odd occasion otherwise reception in arenas, hospitals, big box stores, skytrain, seabus, airports etc...is unaffected.
08-15-2020 03:42 AM - edited 08-15-2020 03:56 AM
@jennynguyen1993 I agree, you should have good reception downtown whats the make and model of your device?
08-14-2020 10:32 PM - edited 08-14-2020 10:33 PM
@jennynguyen1993 wrote:I used Fido before. I even had Chatr before and reception was never an issue for me phone.
Both Chatr and Fido are owned by the same parent company Rogers. The reception at Public Mobile can be much different as it's a completely different network.
As for you being in the centre of a major city, there's always going to be some place (on any network) where signal is bad. Usually, that happen deep into a large buidling or underground.
08-14-2020 10:13 PM
I live in Vancouver, near downtown, so I expect I should have stronger signal as my location is city centre.
08-14-2020 10:11 PM
08-14-2020 02:21 PM
@gblackma wrote:@jennynguyen1993 5he next time that happens try restarting your phone or place it into aeroplane mode for 5 minutes and then take it off. Stay safe.
How does this improve coverage?
08-14-2020 02:20 PM
@jennynguyen1993 , there are only 2 major networks in Canada, Bell/Telus and Rogers. There isn't anything you can do to make the cell providers network work better other than perhaps getting another phone as some phones have slightly better reception than others. Generally, network performance in a major city should be excellent. Anyway, take a look at the cell map and see if there is adequate coverage in the areas of concern to you.
08-14-2020 01:53 PM
08-14-2020 01:21 PM
Who was your previous provider?
You could try different phone, I understand that one was giving no issues before, but just to test service versus equipment.
If you had anything from telus or Bell family the experience should be similar.
Only difference is VoLTE, we don't have it, but that trouble would have different symptoms, you would have great reception but unable to make/receive calls.
08-14-2020 01:11 PM
Check to see where the nearest Bell or Telus location.
https://wilsonamplifiers.ca/blog/finding-cell-tower-locations-the-complete-guide-42c360/
