Changing Voicemail
illyas
Is there any way to change your voicemail?
@Rosguru wrote:
Re Voicemail
Is there a way to reset your name in the voicemail?
 @Rosguru
Click me
Rosguru
Re Voicemail
Daps
@illyashere's a useful article on using your voicemail and changing the greeting
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-To-Use-Your-Phone-and-Plan-Feature...
What do you mean by "change your voicemail"?  If you like, you can record a different greeting message.
Change what? 🙂 Lots of things you can do in the voicemail system.
