05-23-2024
02:13 PM
05-23-2024
09:38 PM
computergeek541
Hi all, I just switched to public mobile plan $29/40gb LTE. It's net speed really bad. Always shows LTE or LTE+ network. But most of the time cannot even open the app. On my previous network speed was 40-60 mbs, now on PM download speed is 2 -5 mbs.
Any leads/tricks to get better speed or leave this network????
05-23-2024 02:22 PM
Thank you bro, will try. I am using google pixel 7.
05-23-2024 02:16 PM
HI @Ash70
what phone do you have?
start with Reset all networks and it should help
if not, you can also try your sim card in another phone. If none of those work, please ask support agent to refresh your account
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
