Poor signal!!!
Fern4
I just switched to PM. Data signal is terrible!!!!  It’s not even good enough to run a speed test. If I switch to my other provider or wifi it is perfect.  Is this normal to have horrible internet connection???
Fern4
Hamilton Ontario and bell towers everywhere. iPhone 13. Just reset. It got a bit better. It actually finished the test but still horrible
will13am
@Fern4 , what part of the country are you situated?  This service runs on the Bell/Telus network.  Take a look at the coverage map and see if you are situated in a low coverage area.
https://www.ertyu.org/steven_nikkel/cancellsites.html?lat=52.025459&lng=-97.031250&zoom=4&type=Roadm...
HI @Fern4
what phone do you have? which carrier you were on before?
start with Reboot phone and Reset Network settings and check again
Also, run a speed test and provide us a result
