Needed to recovery account
Vtan
Need help to recover account, I lost recovery email, can’t login
need help
dust2dust
What recording do you get when you dial 611? What do you mean by "recover account" and "recovery email"?
need help
@Vtan  - are you a current cusotmer?
Note that after 90 days in suspended status OR if you port your Public number to another provider, your account will be deactivated permanently.
Yummy
Contact agent for assistance.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
@Vtan @To change email you need support
Getting help from agent , through automation
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
Or  get direct help from a agent right here in the community ( my preferred choice )
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
@Vtan i guess you tried Reset Password link there, right?
if that didn't work, please open ticket with PM support
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
