wrong plan
11-30-2024
12:53 PM
11-30-2024
01:40 PM
computergeek541
Good day, I am in the process of getting 3 lines with you for my whole family, but didn't realize I needed 3 separate account for each of the family member. Now with my own account, I made the mistake of getting the 23$ plan but I need the 29$ plan (CAN-USA-MEX).
Can you help with to change it before I start the process of transferring my number?!
thanks
Joining Public
Plans
11-30-2024 01:01 PM
great...thanks.
private msg sent
11-30-2024 12:55 PM
hi @bawdy you will need support help and see if they can sort it out for you
you can submit by direct message:
