08-30-2023 06:30 PM
Hi,
I signed up for Public Mobile in July 2023 - I switched from Koodo. I need to requisition records of all incoming/outgoing text messages (including the contents of the message) and all incoming/outgoing call logs since I registered.
Could someone explain to me how I can do this?
Thanks in advance.
08-31-2023 06:50 PM
08-30-2023 09:34 PM
Your messaging app will show all incoming and outgoing texts with the other party.
08-30-2023 06:39 PM
08-30-2023 06:38 PM
just not so sure you'll get contents of all your messages.
08-30-2023 06:36 PM - edited 08-30-2023 06:38 PM
@PoprocksCk wrote:Hi,
Thanks in advance.
@PoprocksCk , I don’t know if Public Mobile can provide the contents of your text messages but you can use @Handy1 link to send a private message to CS_Agent to ask.
Edit:
Customer Support Agents are available from:
A CS_Agent will respond back in your Community mailbox (envelope icon) at the top right of this page to the left of your community avatar on your computer or by clicking on your avatar on your device.
08-30-2023 06:32 PM
@PoprocksCk You can view much if this in your account on the overview page go to the bottom and select option for usage it only goes back 90 days . For anything more specific you need to ask support
send a private message To CS_Agents click
VVVVV Link below VVVVV
08-30-2023 06:31 PM - edited 08-30-2023 06:34 PM
Log in to your account and find the Usage details link under the add-ons list or Shop Add-ons button and you'll find the place listing all your activity.
Adding - called View Usage History. There are three links on the web page overview page.
