Need to cancel subscription from wrong email id
Chris234
Hi
Am Christeena Thomas, today I  tried to change my subscription plan without using correct email id which connect with my phone number and now am unable to cancel the subscription. I need to request a refund for the payment. After making the payment under wrong Email id, which i donot use for my public mobile phone number. I kindly request that you cancel the subscription linked to the EmailID:ckchristy47@gmail.com and issue a refund for the payment made. You can email me in same email id: ckchristy47@gmail.com
2 REPLIES 2
hi @Chris234
first, please update your post and remove your email.  This is a community forum and we are only customers, you have posted the email on the internet
So, you created a separate account while you was trying to make plan change?  You can ask PM support agent to help cancelling it.
 you can submit  ticket by direct message:
slusagm
please remove your email addresses, we are just customers here
yes, PM can help to either change the email address to the correct one or help to cancel it.    Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
