Re: Landline
VEO
Hi I have the same issue. I just started the porting request and now I am not able to log in as the confirmation text is being sent to my landline number. Please help.
1 REPLY 1
hi @VEO
this is normal as porting from landline takes around 3 to 7 days and you cannot receive 2FA text on landline.  The workaround about getting code via email or voicemail won't work until you are able to receive 2FA text once.
so, you will have to wait till the port is done to login My Account.  if you need anything at the moment, please message PM support agent directly.
 you can submit  ticket by direct message:
