01-08-2022 12:18 PM
01-08-2022 01:32 PM
01-08-2022 01:26 PM
Hey @Sape please let us know once you've sent that private message.
01-08-2022 01:25 PM
Where to find your PUK (publicmobile.ca)
- you can send a private message to Customer Support Agent by Click Here link,
01-08-2022 12:48 PM
@Sape wrote:The phone screen reads PUK(4-8)
Have you used this phone on Public Mobile network in the past ?
If it's a new (used) phone...make sure it's unlocked and not reported as Stolen or Blacklisted.
01-08-2022 12:47 PM
Lots of threads lately have discussed this. You'd need to contact an agent to request that PUK (or PIN unlock code). Here's that link again: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
01-08-2022 12:46 PM
01-08-2022 12:29 PM
...for your phone? Or for the SIM? Is your phone unlocked?
01-08-2022 12:28 PM
@Sape wrote:Can’t use phone I need a new 4digit pin
Do you need a new voicemail PIN? or a new PIN to access 611?
For voicemail, login to selfserve.publicmobile.ca, and on the overview page click "Reset Voicemail Password".
For 611 PIN, you'll need to open a ticket with the CS agents to change it if you don't remember what you entered when you activated your account.
The chatbot/automated ticket creation system is a little finicky the last week or so, so you might fare better by sending a message directly to the CS agents using this link:
Good luck!
