Thursday
Can I get a plan for the avove from Public Mobile? If not, what do I need to do?
Thursday
Short answer: No — Public Mobile doesn't offer any service options for Europe.
Public Mobile's only available roaming add-ons cover the US (and some plans also include service in Canada/US/Mexico).
What you can do instead:
Important tips:
Thursday
You will need to purchase a local SIM in Europe. No roaming in Europe on PM.
The other option is to download the TextNow app and pick a secondary number and you can use it for calling and texting when connected to wifi or to the data on the local SIM.
Thursday - last edited Thursday
to keep in contact with fam and friends back home....use WhatsApp. You and those family and friends must download the free WhatsApp. When you get to Europe or wherever, you'll be able to freely message and talk using local wifi or separately purchased data. Here's a link to travel data esim; airlo...used by many Cdn travellers...
https://www.airalo.com/europe-esim
You'll be able to use the data to send / rec calls and texts using WhatsApp, whilst you're away.
sp
Thursday
PM does NOT provide service outside of this continent.
