01-21-2021 12:42 PM - edited 01-05-2022 04:57 PM
I lost my user ID and password, I just need my account number of my public mobile
please help me
01-21-2021 02:07 PM - edited 01-21-2021 02:09 PM
@Javedraza wrote:I lost my user ID and password, I just need my account number of my public mobile
please help me
Hi @Javedraza as already mentioned above by @hairbag1 , you can also find your account number in the welcome letter Public Mobile had sent you.
I hope this helps.
RosieR
01-21-2021 01:10 PM
Your user ID is the e-mail address used to activate the account. If you have many e-mail accounts, I'd recommend doing a quick search of your top used e-mail services - just search "public mobile". When you get a hit from the one used for activation - you're half way there.
Once you enter that e-mail address, and if you forgot the password, use the "Forgot Password" option and you'll be sent a link to change the password to the registered e-mail address.
01-21-2021 12:55 PM
@419mainstreet wrote:If you forgot or want to modify your Self Serve email, you will need to contact a Moderator.
OP needs their info in order to use the link you've provided. 😷
01-21-2021 12:52 PM
01-21-2021 12:51 PM - edited 01-21-2021 12:52 PM
please help me
Did you write that info down when you first activated and store it somewhere ? (Good idea to keep that info written down )
Did you happen to save the Welcome to Public Mobile email ?
01-21-2021 12:48 PM
Here’s when and how to contact the Moderator Team:
