a week ago
Hi everyone, I dropped my phone a year ago and it messed with my sim card tray. The solution was to move to esim and it seemed to work. Unfortunately I didn't learn how to not drop my phone again so flash forward a year I dropped my phone again and I kept getting an error code about the SIM tray again even though I was using an esim. It eventually kicked me out despite saying I was connected to my esim. I couldn't make calls or texts. I had to do a network reset and it didn't seem to do anything. I updated my phone and now it says emergency calls only instead of no service. I need help on reconnecting to my esim in case doing the network reset kicked me out forever. Please help?
a week ago
@Amandala wrote:I was able to log in but no option for a free sim it says $5
it is free if your last eSIM ordered with more than 15 days ago
But PM support will usually reimburse you the cost if you experiencing technical issues and need a new one to resolve it. Buy the new one first and open ticket for PM CS agent to request reimbursement
Please open ticket with PM support:
a week ago
a week ago
This didn't work unfortunately. When I go through the app to order a e-sim it still says it's $5+ are you sure it's free?
a week ago
Almost sound like a device problem
But check if you can login PM app. If you can login, then get a replacement eSIM for free from Account -> purchase sim card and select eSIM
a week ago
@Amandala wrote:Hi everyone, I dropped my phone a year ago and it messed with my sim card tray. The solution was to move to esim and it seemed to work. Unfortunately I didn't learn how to not drop my phone again so flash forward a year I dropped my phone again and I kept getting an error code about the SIM tray again even though I was using an esim. It eventually kicked me out despite saying I was connected to my esim. I couldn't make calls or texts. I had to do a network reset and it didn't seem to do anything. I updated my phone and now it says emergency calls only instead of no service. I need help on reconnecting to my esim in case doing the network reset kicked me out forever. Please help?
Turn your phone's Airplane mode on. Then turn off your phone for 5 minutes. Then turn the phone back on, turn off Airplane mode. This will reconnect you to the network.
You can go into your settings and see if your eSIM is still there and if it's set as Primary. If your eSIM is gone, then download the app and purchase a new one. They are free after the first purchase so when you get to check out, $0
