Need help manually porting a number
2BBB
Something went haywire when I tried to do it on the web. Haven’t received any notification from my old provider and it’s been over 90 minutes
CSA_PM
Customer Support Agent
Hi 2BBB
Please try sending a private message. Unfortunately I am not able yet to contact you privately .
Dunkman
@2BBB
I tried to escalate your issue with customer service agent. CSA_PM should get contact with you via private message.
Chalupa_Batman
So you said YES to the port request from your other provider? If so, then place your PM SIM card in the phone and reboot. You may also have to reset your Network Settings so it clears out your old provider to find PM's network. If you still need help, here's how to reach PM.
The Public Mobile chatbot is currently unable to create trackable tickets for members who are unable to log in. So for this reason, please use the following link to contact customer service.
Meow
You would have to open a ticket through chatbot and ask agent for assistance.
Phone number you might get from some customers through personal mail is Not meant for such assistance and will be frown upon if you use it. Go Legitimate way - Ticket!
