Phone Number port stuck
JaceyWynnyk
@softech Hello, Would it be possible to also get this number from you for the live support? I ported my phone number and then my husbands and now they have been mixed up with each other and I cannot get a hold of anyone to help me. Thank you!
1 REPLY 1
@JaceyWynnyk
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
But if you are unable to reach a live support with the phone number I sent you, please message the the support team using this link instead:
