NO service
01-16-2022 11:24 AM
I have not been able to receive calls, when i am called it says that my number is either out of range or service, it says its a foreign number.
Service
01-17-2022 01:22 PM
01-17-2022 01:21 PM
Sorry @husna_bk from your reply, I am not 100% sure I get what you said about whether the number was from another provider or not . you said:
uhum no its from another provider, Tellus.
it is a new number
So, is it a new number you got from PM or a number transferred into PM from Telus?
Either way, maybe try to open a ticket with PM Support first and have them confirm:
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
01-17-2022 01:13 PM
yes i am
01-17-2022 01:13 PM
It is a recent problem, it is a new number so no the service wasnt working originally
01-17-2022 01:12 PM
I only got the number a few days ago, uhum no its from another provider, Tellus. yes i am able to make calls without a problem
01-16-2022 01:36 PM
you activated new line do you getting new number or you Transfer old number to public mobile, if so
do you get a SMS message from your old carrier asking to confirm if you would like to Transfer your number. Your reply should be: YES.
if you stuck with Transferring your old Phone Number, or is not complete processing
Here’s how to contact Customer Support Agent by CS_Agent,
- you need to send a private message to Customer Support Agent by CS_Agent, by Click Here link.
- please include in your message,
- phone number,
- which carrier,
- Customer Support Agent by CS_Agent, will Response to your inbox by private message
- During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
- Monday to Sunday: 6 AM to 10 PM EST
- Note: Public Mobile No Support by phone call or Email.. only by CS_Agent, private message..
- Check your private message inbox (click on the envelope top right of your screen)
you can also do some troubleshoot
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
APN Settings On An IPhone click Here link,
- Open the Settings app on your Android.
- Scroll to and tap either "General management" or "System," depending on what device you have.
- Tap either "Reset" or "Reset options."
- Tap the words "Reset network settings."
or visit Here link,
APN Settings On Android device click Here link,
Ensure you have the correct APN settings by visit Here link,
Select the brand and model of your phone,
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
try to check update your device,
you can try to test your SIM card in another device to you know the issue from SIM card network or your device issue.
if you can't fix it you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to them can solve, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent,
- send a private message to Customer Support Agent by Click Here link,
01-16-2022 01:14 PM
@husna_bk wrote:I have not been able to receive calls, when i am called it says that my number is either out of range or service, it says its a foreign number.
Try manually forcing your mobile connection on your phone to 3G or WCDMA ONLY temporarily to see if services improve.
Also - This may not apply...but, do you live by a Canada/USA boarder? If so, turn off your Roaming option on your device.
01-16-2022 11:36 AM
@husna_bk as many said, sound like a porting issue
you can call out without issue? and data no problem?
If you have just activated and requested porting? you replied the text from the previous provider with a YES within 90 minutes?
There is a number to call for Porting status, I can message you via Community inbox. check Envelope icon on top right
01-16-2022 11:28 AM
In order to be able to better help you, I have a few questions:
(1) How long have you had this number?
(2) Did you get it as a new number from PM, or did you port it in from another provider?
(3) Are you able to make outgoing calls without problems?
01-16-2022 11:27 AM
Did you bring your number from a previous provider? Or did you select a number at activation? Is this a recent problem? Did the services used to work?
Contact a Customer Support Agent
01-16-2022 11:27 AM
What your PM account says? Is it status Active?
Can you send/receive SMS? How about Internet?
When it stopped working and did you have regular service before that?
Are you at the same place as usual or you out of range of cell towers?
01-16-2022 11:26 AM
Are you calling from Canada?
