NO INTERNET CONNECTION outside my WI FI usage
rita1
Hi ,
This is very very disappointed .
Since the past weeks , I had serious problems ( accidents) and I was UNABLE TO USE INTERNET.
It keeps on saying : No internet connection. I had to use POLICE"S internet connection.
I have NEVER been able to use my 2G DATA outside my place.  I always used my WI - FI but outside the WI FI , I am unable to use my data.
Can you please look into this serious matter before we all go to other competitors.
Thank you and hoping this issue to solved today.
Have a great day.
R.R.
12 REPLIES 12
@rita1
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and you can try to reset network settings and Changing APN Settings,
Spoiler
for IPhone
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit  Here link,
click Here link,
How to reset network settings on an Android device
  1. Open the Settings app on your Android.
  2. Scroll to and tap either "General management" or "System," depending on what device you have.
  3. Tap either "Reset" or "Reset options."
  4. Tap the words "Reset network settings."
   or visit  Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,
if you can't fix it you need to Contact Customer Support Agent by CS_Agentand Explain your issue to
they can solve your issue, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
Spoiler
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Support Agent by CS_Agent,Click Here link,to get started. Type,, Ticket ,, Click ,, Contact Us ,, Select your issue ,,
    Click here to submit a ticket↗↗.
  • or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
  • phone number,
  • account number,
  • account 4 digit pin,
  • Email address,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
  • During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
    • Monday to Sunday: 6 AM to 10 PM EST
         Good Luck....
for more information about Managing Your Data Usage visit  Here link to save your data...
and turn off background data, to save your data.
when your data limit used all, is will be off until next renewal cycle,
at public mobile 30 day Prepaid Service No fees extra charges,
@rita1 @wcindor
The changes are that your data setting is turned off. Depending on what phone you have, just click on Settings>Cellular>then check if Cellular Data is enabled.
hairbag1
@rita1...we all understand how you could be so disappointed, but we need a bit more info. You've taken the time to let us know what the problem is...so. stay with us long enough to solve it if we can. This is a Public Mobile Community forum, made up of users just like you and I...we're not PM employees. We've been around long enough that we can probably figure out the cause of your vexation, but c'mon...stick around and help us help you.
There's already been a few reply's to your question. My reply is ...what kinda phone are you using (make & model) ? Are you fluent enough to know how to check your APN settings ?
t_p
@wcindor wrote:
I just my phone bill but I do not data on my phone when I am outside home.
@wcindor
If you have issue similar to @rita1 , check my post above.
@wcindor   Just to confirm, so, both incoming calls and outgoing calls are working and just not mobile data?
did you try to use mobile data on different apps (browsers, Facebook, email, whatsapp, etc)
What kind of  phone is yours (brand and model)?
and mobile data NEVER works or just stopped working today?
can you check your APN settings again:
Android: https://publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
iOS: https://publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-iphone
or post a screenshot
wcindor
HALIMACS
Hi @rita1
Please refer specifically to this section (below) of your self-serve landing page to see if you have any Data allotment remaining:
If you don't, you can add data by purchasing an add-on to hold you over till your next cycle renewal.
Here's how:
  1. Click on ‘Purchase Add- Ons’ on the Overview tab and scroll down to the Add-On calculator.
  2. Click the plus sign (+) to add and the minus sign (-) to remove selected Add-ons.
  3. When you’ve added all your desired Add-Ons, click ‘Buy Add-Ons’ or ‘Make a Payment’ below the calculator:
    • You will see ‘Make a Payment’ instead of ‘Buy Add-Ons’ if there are not enough funds in your account to make the purchase.
    • If you don’t have sufficient funds to purchase the Add-Ons, you will be asked to make a one-time payment equal to the price of the Add-On, less your current available funds. Click ‘Submit’, then ‘Go back’: now the button below the calculator will say ‘Buy Add-Ons’.
  4. Select ‘Confirm my purchase’, and you’re off to the races!
Meow
Assuming DATA is turned off and you still have available data allotment on your account.
Log in into your account and check (provide screenshot) of your available data.
Were you able to use internet ever before?
t_p
@rita1 wrote:
Hi ,
Have a great day.
R.R.
@rita1
If you NEVER have been able to use data, your SIM might have a provisioning issue.
First, verify your APN settings as suggested above, but if it doesn't help, contact Customer Support:
Spoiler
Open a ticket via:
https://widget.telus.tiia.ai/publicmobile/publicmobile.html (faster response time)
Type "ticket" > Click "Contact Us" > Select your issue > "Click here to submit a ticket↗"
or send a private message to:
and describe your issue. Include your name,phone #, account #, Email address,4-digit PIN to speed up authentication process.
You could also try to reset Network settings or do a factory reset as last resort.
Edit: You could try swapping your SIM with another (working) phone to see how it goes.
      - If another SIM works in your phone ===> Your phone settings are OK
      - If your SIM works in another phone ===> Your phone settings are not OK
      - If your SIM doesn't work in another phone ===> There is an issue with your                   account/SIM
Dtack
@rita1  - I would  try turning your phone on and off, then reboot, go to airplane mode for a few minutes and then go back to regular mode, remove SIM card for a few minutes and reinsert, reboot phone, do a network reset .  This has worked for me in the past.  Good luck!
Triguy
Log into your account to check your data allotment.  If no data is listed then it means it has been used up.  Try rebooting your phone.  Check to make sure you have the correct APN settings.  You may also need to do a network reset.
