NEW PIN # NEEDED
Cunard
MY CELL IS LOCKED, HOW CAN I GET A NEW PIN
self solution removed
Cunard
Thank you for your help. I got back my PIN as soon as i contacted the agent.
Good service
@Cunard wrote:
SAMSUNG FLIP WANT TO TRANSFER SIM CARD TO NEW ONE, BUT ON THE SCREEN SAYS : PUK LOCK
AND CONFIRM PIN CODE. I THINK IT'S FOR THE SIMM CARD?
THANKS
@Cunard
What was the exact error message?
If the message is “PIN unlock key (PUK)” or "Enter PUK Your SIM  Card, SIM cannot be accessed
         open message support here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
          or use this direct link to open Chatbot ticket:  https://urlshortner.tiia.ai/Oyn1L6
            **Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply to you
there.
JRod
@Cunard
Yes that PUK code is for the SIM Card. Please reach out to customer service and they’ll be able to get you going.
Please click this link below to message customer service:
Keep an eye on your mailbox here as that is where your reply will come in (envelope icon on desktop, click your avatar icon in the corner and then click messages if on mobile).
Cunard
THANKS
JRod
@Cunard
Are you referring to the PIN for your SIM card or for your phone?
If it’s for the SIM you will have to contact customer service.
If it’s for the phone what kind of phone do you have?
