06-26-2023
05:26 PM
06-26-2023
05:42 PM
computergeek541
06-26-2023 05:45 PM
@WS101 give PM another chance, it is an easy fix for them. You can message them once again for update 🙂
06-26-2023 05:44 PM
Okay, i messaged one of these chat messaged in the link you pointed to over 1 hour ago with no reply. I will give it one more hour.
But it seem the solution may be to ask for a refund to be honest.
06-26-2023 05:41 PM
@WS101 wrote:No luck the phone was rebooted may times, and still no confirmation codes come through to complete the app setup on the phone
@WS101 what Samsung phone do you have?
again, it looks like a sim card provisioning issue. To engage support, you need to message them as advised above. It is an easy fix for PM support, you just need to message them 🙂
06-26-2023 05:40 PM
06-26-2023 05:39 PM
@WS101 sorry, PM support is all online, no phone number to call. But you are close to done the activation.
Try to reboot the phone again and see if the phone connects to the PM network. It should
If not, you might have to message support and ask them to confirm if sim provisioned properly
06-26-2023 05:38 PM - edited 06-26-2023 05:39 PM
@WS101 Yes I sent it to your in box or use this link to it
add disregard wrong thread sorry
06-26-2023 05:37 PM
Is there a call in number? I cant seem to find proper support and don't understand these chat robots. The sim card arrived and was put into my Samsung android phone, the app was downloaded and a number was chosen. Then when a confirmation code was to arrive to the phone it never came through.
06-26-2023 05:28 PM
@WS101 Did you reboot the phone with SIM card in phone . But to reach out to support you need to message them
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
06-26-2023 05:28 PM
@WS101 give us a bit more details. PM already charged you the plan amount?
You got pass the stage of picking a new phone number or request porting in phone number?
did you try your PM sim card in the phone? was it not able to connect?
what brand and model is your phone?
it could be sim card provisioning issue. So, you can try to reseat your sim card or try on different phone.
If still not connecting and again, if PM charged you, open ticket with PM support and have them to confirm sim provisioning was done properly. Message them here:
06-26-2023 05:27 PM
as part of the Activation process, did you attempt to port your old number to PM ?
