12-27-2022 01:38 PM
Hello,
I can’t remember my login email to renew my plan.
I know my public mobile number associated with it.
could someone help me.
thanks
12-27-2022 03:33 PM
You will need to contact a CS_Agent to help you access your account.
Meanwhile, you can purchase a voucher from these location and dial 611 to enter the voucher number to restore service:
Or you can purchase voucher an online at recharge.ca.
12-27-2022 01:40 PM - edited 12-27-2022 01:44 PM
@Baldevdhilon if you remember your 4 digits pin, you can make a payment to resume service using * 611
If not, you will need to get the login issue resolved first, open ticket with Pm Support using chatbot:
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
if you don't want to wait to "unlock" the login , you can also get a voucher from SDM/711/Shell and then load the voucher using *611 (no 4 digits pin needed) (Try to buy vouchers from those stores as their voucher can be used immediately. Vouchers from other stores could take 24 hours before they can be used)
