Forgot email
ckeesman
Hi,
I set up an account for one of my kids but I don't remember the e-mail address that I used to set up the account.  I have the phone and can reset the password but I don't know how to reset/retrieve the email address.
Thanks.
@ckeesman @To change your email , you need help from agent . My second link is best way
Getting help from agent , through automation
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
Or  get direct help from a agent right here in the community ( my preferred choice )
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
Outdoorsman
@ckeesman
Hi to change/reset account email you need the help of a service rep
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or  private message them here
@ckeesman   you have tried to use the Reset Passowrd link there?  You can put in any possible email address and see which one get the reset password email from PM
if that does not work, open ticket with PM support using chatbot
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
