My mew Sim card does not seem to work?
faja66
Lost my phone had to get a new sim card. Its doing nothing! Are there some manual settings i need to worry about?
19 REPLIES 19
faja66
Ok i will open up a ticket.
Ty all for support.
faja66
Ty just did this and its ok
dust2dust
Did you try the sim in another known-working device?
@faja66 @It could be a provisioning issue in which case you would need supports help contact a CS agent
@faja66
Additionally, is the replacement device you acquired brand new and are you sure it isn’t either locked to a prior carrier or perhaps blacklisted?
Check here:
https://www.devicecheck.ca/check-status-device-canada/
@faja66   if you login to My Account, Profile page, check the sim card number, does it show number of the new one?
and try it on another phone as well
I guess if it shows the new one, you tried different phone, you have done everything correctly, you will have to open ticket with PM Support at this stage:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
faja66
Did that already ive done everything as suggested
WolverineCaz
That's good, there's always the possibility of a lemon. Does it look damaged at all?
faja66
I used a desktop
faja66
As far as i know its set correctly. But that is a possibility
faja66
Already did that
@faja66 wrote:
Ive done that 10 times already
@faja66  you likely have been using your phone or tablet to do that
Please using a desktop or laptop computer.  There is problem for that part of the site if you use mobile phone
Did you change the SIM card # associated with the account? And I presume this is a brand new public mobile SIM card - it needs to be.
The only other thing I can think of is whether you set the account in a lost/stolen mode. If you did, that will have to be removed.
EDIT: also @faja66 is the replacement device you acquired brand new and are you sure it isn’t either locked to a prior carrier or perhaps blacklisted? Check here:
faja66
Already done that. It says that its registered ok
@faja66
My account
Legend  and features
Change plan / update cc /auto pay
Account #/ change # port
on a computer go to profile page and SIM SWAP if you haven’t already
faja66
@faja66   did you login to My Account and request Change Sim card?
Login to My Account using only a desktop or laptop computer (there is problem with using it on mobile device)
Click on Quick link on top right and select Change sim card and follow the steps
https://selfserve.publicmobile.ca/en/account/edit/your-accounthttps://selfserve.publicmobile.ca/en/account/edit/your-account
HALIMACS
@faja66
all you need to do is log into your self serve account and go under the Change Sim card function under your profile.
After you have updated the SIM card, put the SIM card in then reboot your device, and you should be good to go.
WolverineCaz
It should be just plug and play. Try restarting the device. Make sure the card is seated correctly and try again.
