09-13-2022
05:45 PM
09-13-2022
10:16 PM
computergeek541
my iphone will not connect to public mobile. It shows "Searching" and I am unable to use any cellular service.
Phones
09-13-2022 08:38 PM
I did this and everything seems to be up to date. I put the sim card in another iphone and it works.
09-13-2022 07:51 PM
hi @k_j_mac
did you check if your Carrier profile is up-to-date?
- Connect to Wi-Fi.
- Go to Settings -> General -> About
- Wait for 10 seconds.
- If an update is available, a window will appear that asks if you would like to update your carrier settings. If an update is available, tap Update or OK. If nothing happens, your carrier settings are already up to date.
09-13-2022 07:33 PM
I think the phone needs to be registered to Apple. You can login to the Apple ID from a computer.
09-13-2022 07:32 PM
09-13-2022 07:29 PM
The sim card works in another phone. When I put the sim card back in the original iphone it caused the phone to reset and shows Hola and wants me to enter my apple id. Unfortunately I do not remember the apple id.
09-13-2022 07:16 PM
I don't think we're anywhere yet needing a factory reset. That is last ditch hail mary. Answer some more of the questions.
09-13-2022 07:14 PM
09-13-2022 07:11 PM
I believe it is an iphone 6
09-13-2022 07:11 PM
09-13-2022 07:09 PM
Hey, I have a iPhone kicking around my place and I don't know whether the model matters, I presume it doesn't, it case it does it's the original SE, anyhow, when I used to use my iPhone as my daily driver I noticed that the service would not stay connected, it would be in and out, from Public to Searching... What I did to solve my problem is I went into the Cellular settings and changed the Carrier from Auto to Manual and then chose Public (I think it actually shows up as Telus since Telus owns Public) and after I did that I never had a connection problem again.
Hope this helps. 🙂
09-13-2022 07:09 PM
@Remember- They have an iphone.
09-13-2022 07:04 PM - edited 09-13-2022 07:06 PM
no need new phone yet, what phone brand and model?if can backup and do Hard Reset.
09-13-2022 07:04 PM
Did the phone somehow get set to 2G? And if you put the sim back in does it work? Can you try a different working sim in the phone?
09-13-2022 07:00 PM
I took out the sim card and reinserted it. The phone reset. I then put the sim card in another phone and it worked. I guess I need a new phone!! 😞
09-13-2022 06:11 PM
This is not a new phone and have been with Public mobile for 2 years without issue until today.
09-13-2022 06:10 PM
09-13-2022 06:03 PM
Hi @k_j_mac did it ever work on another network before? or you just got it and never able to connect to any network?
do you have another sim card with another carrier to test the phone?
if it is a new phone you just got chexk the devicecheck.ca to confirm the phone is clean
