Lost Sim card
09-13-2022 04:30 PM
Lost my sim card, have a new one.
Cannot log in to my account to activate it.
Help!
My Account
09-13-2022 08:13 PM - edited 09-13-2022 08:14 PM
Clear the cache, cookie and go incognito then try login. Click on Change SIM card not activate the SIM.
09-13-2022 05:34 PM
WHY you cannot log in? Forgot password? Account deactivated? More details are needed.
09-13-2022 04:32 PM
@Bryanhou is it problem with 2FA or password problem?? Can you have the 2FA code send to email?
if you really cannot login, open ticket with CS Agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
- First type: "Forgot log in information"
- Then Click "Contact Us"
- Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
