3 hours ago
- last edited
3 hours ago
computergeek541
I have been sending texts internationally which is covered under my plan with no luck. They have never been delivered. Any tips on what c the reasons could be
Thanks
3 hours ago
Not all the time especially if the receipt doesn't have internet available all the time. So sending text would help reaching out when the receipts internet is off
3 hours ago
3 hours ago
You can download the WhatsApp and you can make calls and text around the world for free when you are connected to wifi.
3 hours ago
Yes that what I have been doing
3 hours ago
@Mariu wrote:I have been sending texts internationally which is covered under my plan with no luck. They have never been delivered. Any tips on what c the reasons could be
If you're trying to send these text message with the phone number formatted as 011xxxxxxxxxxxxxx, try using +countrycode (whatever the country's code number is) followed by the rest of the number instead.
