yesterday
- last edited
yesterday
computergeek541
Is this possible? I'm on the activation screen for the past week or so and would like to cancel enrollment in service and get a refund.
yesterday
@Gkdefineds wrote:Is this possible? I'm on the activation screen for the past week or so and would like to cancel enrollment in service and get a refund.
Officailly, the policy is no refunds. Which phone model do you have? As for the activation screen, what error message are you receiving? In cases of an eSIM not working on a device, Public Mobile can provide a physical SIM card to use instead. Please open a ticket using the chatbot and ask a Public Mobile customer support agent for hlep: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
yesterday
@Gkdefineds you might be able to do that but you will need to reach out to a customer support agent by clicking on the orange round circle in the bottom right of your screen and type: Customer Support Agent
Or, if you are having trouble with the Chatbot try sending a private message to:
Did you want to try telling us what message you are getting or where you are stuck on? We might be able to help if you are still willing to try
yesterday
was that esim issue?
but yes, it is possible to cancel, just message PM , and maybe before you cancel , ask them what they can help with the incompatibility issue
