11-16-2024 06:04 PM
Hi,
I am in Hong Kong and when I turn on primary voice line, I got no connection to any provider. I have another data eSIM but I want to be able to receive texts. Does Public Mobile voice/text roam with international carrier?
Thanks.
11-16-2024 10:03 PM
11-16-2024 09:32 PM - edited 11-16-2024 09:59 PM
Thanks, good to know you confirmed it works in Europe as long as you download and registered a Canadian or USA area code.
I have the TextNow SIM which I use while I am in the USA. My TextNow includes data.
11-16-2024 09:26 PM - edited 11-16-2024 09:27 PM
hi @BKNS27 actually not true
maybe you can only register when you're in Canada or us but you can use the service even you're in Europe
I just tried it last month and all works well in Europe
so I suggest to register textnow when you're in Canada before your trip, then you can use it anywhere
11-16-2024 08:54 PM - edited 11-16-2024 08:55 PM
@BKNS27 wrote:You can use WhatsApp for free calling and texting through wifi while you are in HK.
@hTideGnow & @Chalupa_Batman TextNow have changed their service to only operate in Canada & USA.
According to their TOS, I read this.
Those who access or use TextNow Properties from other countries do so at their own volition and are responsible for compliance with local law.
But if you can find a directly link or correlation to their TOS, please feel free to post it.
11-16-2024 08:36 PM
11-16-2024 06:24 PM - edited 11-16-2024 06:26 PM
@Lu613 , if you are using RCS format for messaging you will be able to communicate via RCS with contacts that also use RCS. RCS has been available for android devices for some time. It's recently available for iPhones on iOS 18. Make sure to enable the Public Mobile SIM as default for voice and text, e-SIM for data. A mobile connection is not required on the Public Mobile SIM.
11-16-2024 06:18 PM
hi @Lu613
sorry PM has no roaming service other than US
So, you won't be able to get any calls or texts while you are in HK
if you have Mobile data there, you can try using BoIP app like Fongo or TextNow to her calls and text on another number provided by the VoIP app
11-16-2024 06:17 PM - edited 11-16-2024 06:18 PM
@Lu613 wrote:Hi,
Thanks.
Hello @Lu613
Public Mobile only works in Canada and the United States. The only way you can MAYBE get messages is if you used an iPhone and had some sort of data eSIM out there or Wifi. Other than that, the only suggestion I can make is for you to use a VPN on your phone and pick Canada, then download an app like TextNow and pick a local number to where you live. Then, using WiFi or a eSIM data plan from HK, you could at least communicate with everyone back home free.
