07-29-2020 09:24 AM - edited 01-05-2022 12:18 PM
I have data and I turned on data on my cell and not working ...
My phone works but data not.
Also I cannot send or receive the picture mesage.
Thanks
07-29-2020 10:52 AM
07-29-2020 10:50 AM
@Lorin33 wrote:I do not have iPhone
I have ACER
Your first post said iphone. Is that like Kleenex? 🙂
07-29-2020 10:48 AM
I have ACER
07-29-2020 10:45 AM
@Lorin33 wrote:I have data and I turned on data on my cell and not working ...
My iPhone works but data not.
Thanks
As mentioned reset your APN settings, reseat the SIM card and reboot your iPhone.
What model of iPhone do you have?
07-29-2020 10:14 AM
@Lorin33 Which model iPhone do you have?
iPhone 3/4 APN settings cannot be updated manually. You will need to connect to wifi, access http://www.unlockit.co.nz/mobilesettings/ with Safari, then follow the directions there.
MMS text will not work with iPhone 4.; detailed info is here: https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/FYI-iOS-and-APNs/m-p/323119/highlight...
07-29-2020 09:37 AM
07-29-2020 09:31 AM
Hopefully the network reset clears it up, but just in case here's a KB article that has other suggestions to try: https://support.apple.com/en-us/HT201415
07-29-2020 09:28 AM
@Lorin33 try a network reset and restart your phone if it doesn't automatically do so.
Go to Settings > General > Reset > Reset Network Settings. This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before.
Stay safe.
