My data is high and I am not the one that is using it
JMF
My data is being used at times when I am asleep and not using my phone.  When I turned my phone off last night until this morning, my data was still being used.
CGO
turn off background apps on data.
darlicious
@JMF
Data usage is updated twice daily representing the preceding two 12 hour periods of usage from midnight to noon and noon to midnight (eastern).
Yummy
If you keep data on and phone on all the time, apps might and will use your data.
PM might use minuscule amount of data for its services (and will return it) but I do not see that anymore on my usage report.
Provide screenshot of data usage during wee hours While your phone is off.
HALIMACS
@JMF
Public mobiles data usage history is only updated twice daily.
It represents data consumed within the 12-hour preceding period.
Quigley
@JMF
During those times, your wifi maybe cutting out and your data is being used to update apps and what not, with out you knowing.
If you're phone is turned off though, then your probably noticing that the PM system has added up all your data used before you turned it off.
