11-24-2024 06:46 PM
Everything was fine, for years. Over the last year signal has gotten weaker, and now it has become worse. Even if I go outside and go some place high up to get 5 bars, it fails to connect for voice. It just keeps dialing and dialing until it times out. Cannot connect to voicemail. I notifies me when I get one recorded. But I cannot connect to listen to it.
And this web site is worse than awful. It just keeps sending me around in circles. If this doesn't improve I will be going elsewhere. I have no choice. I live alone and am 69 years old, and I *need* my phone to work.
11-24-2024 08:34 PM
What is involved in 'activating' a *new* sim?
I was hoping to avoid that buy finding a phone that will accept the SIM from my old phone.
11-24-2024 08:28 PM
Thanks for your input. I think there are at least 3 sizes of physical SIMS as well as the new digital SIM. The reason I'm paying attention to the size is precisely is because I hope to find one that *can* use my existing SIM card. I'm hoping to avoid any complications of trying to get a new SIM to work. I happen to have the 12mm x 15mm physical SIM, so if anyone can recommend a good dumb phone that uses that size of SIM I would welcome the input. I also would like it to be a new phone because I don't like buying used electronics of any kind.
11-24-2024 08:19 PM
@angryoldcuss wrote:Thanks. I'm trying to find one right now. The SIM cards come in a few flavours it seems. Trying to find a good one with the same size SIM card.
I don't think you need a new sim...just get a new ( or refurbished ) cellphone. Your old sim will likely work just fine. If there's a Mobile Klinik in your area, give them a call and ask about refurbished cellphones.
11-24-2024 08:10 PM
hi @angryoldcuss all PM sim card are pretty much the same
Buy a PM physical sim card from Telus or Koodo or Mobile Klinik stores or via Amazon:
Telus or Koodo or Mobile Klinik store https://www.publicmobile.ca/en/on/pick-up-SIM
Amazon.ca https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/
11-24-2024 08:06 PM
11-24-2024 08:03 PM
@angryoldcuss wrote:Yes I have, please see above. I've been wanting a new one, but dread the headaches of getting the new one to work.
Once you get a newer cellphone, you just remove the PM sim from the old phone and install in new phone...that's it. The tough part will just be learning to navigate the new cellphone features, but your PM talk/text/data will work just fine. If you have any doubts....be aware that there's a room full of old guys here to help you figure things out.
11-24-2024 07:12 PM
i meant if you open support ticket with PM, they might not be able to help much, they will ask you to upgrade your phone
11-24-2024 07:11 PM
What is PM support?
11-24-2024 07:11 PM
get a ZTE Cymbal 2, cheap but reliable phone and works
11-24-2024 07:09 PM
with Galaxy SIII being so many years ago, the reception issue could be a phone problem instead of the network. And I am certain PM support won't be able to do much. Time for a new phone 🙂
11-24-2024 07:07 PM
That is exactly right. I don't run any apps (I'm fond of my privacy) and was hoping to get a "dumb phone". Do you know if they work with my existing SIM?
11-24-2024 07:04 PM
S3 is a bit too old. It is a 12 years old phone!!
if you use it as a smart phone, it probably not safe and you likely cannot install apps, and browser not able to access many sites
if you are not using it as a smartphone, probably better to spend $100 for a old style clam shell phone
11-24-2024 07:03 PM
11-24-2024 07:00 PM
Yes, it is an old Galaxy S III, and is not on the list of instructions for resetting the network settings. Should this SIM work in another phone?
11-24-2024 06:52 PM
what phone you have? could be a problem with 3G and VoLTE. Maybe your phone is not on the VoLTE whitelist and you don't have good 3G coverage now where you are
try Reset Network Settings and see if that helps
or try your sim card in another phone
11-24-2024 06:52 PM
have you had the same cellphone for years too...maybe time to upgrade if it's an oldster.
